Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: tuning options mk4 gti
    May 2010
    jarvis bay
    first of all i am new to forums and i have only owned my golf gti mk4 for a few months... i wanted to know is there a piggyback controller for the standard ecu...i used to have a subaru wrx sti and i had a " uni chip" it was great is there something like this for golfs???? all i can manage to find is places that want me to send them my ecu or go to a complete stan alone system due to bad experiences i dont want that option.. any info would be helpful
    p.s. i have the following mods already
    ths front mount cooler
    aem intake kn filter
    2.5 inch exsaust
    thanx
    Welcome to the forum.
    There's no need to do the unichip or standalone, it's not the way to go. There's other options, I hesitate to say plenty. Some can flash your ECU, I am one of them, other's will want to install another chip in your ECU.
    The ECU will most likely need to be removed from the car for the flash as I haven't come across a port flashable MK4 in Australia yet. I use a bench lead to flash them.
    In you list of mods, you haven't mentioned a downpipe, is that still standard? That would limit you to a Phase 1 from Custom-Code. It would still produce more power than an otherwise standard car but you wouldn't be able to wring every last hp from it, without the dowpipe, which would take you into Phase 2 territory.
    Dec 2007
    Girraween
    If you want to run a decent turbo then stand alone is your only option. What kind of turbo will you look at fitting?
    Euro Revolution - eurorevolution@live.com.au
    Importing Quality Performance and Spare parts for Audi & Watercooled VW's
    New website almost up and running ... http://eurorevolution.webs.com/index.htm
    Courtney
    Jan 2009
    blankedy
    Are you sure its not already chipped? With those mods I would assume it was...
    May 2010
    jarvis bay
    im not too sure to honest it has a downpipe but not a catback i know it is strange not to do both at once but it came like that it has a few other minor mods like one of them n75 valves oh and i will be gettin the cat back aswell ... probly will be runnin a k04..wat r they like on mk4s ...
    A K04 is fine on the stock ECU even a GT28 with an aftermarket controller. You will need bigger injectors and the other hardware to fit the K04 in place of the 03 and a few other things. As Gavin mentioned above the ECU has to be removed from the car and modified but the results are well worth it, we have done a few now too.
    Hi Gavin,
    What flashing tool do you use for the MKIVs? I do them all via the OBD. EDC15. Do you use a CMD tool or Alientech?
    ??? EDC15 that's nothing like the ECU in the Mk4 GTIs here. Maybe in Ireland though
    Quote Originally Posted by parso_rex View Post
    ??? EDC15 that's nothing like the ECU in the MkGTIs here. Maybe in Ireland though
    LOL I should have posted ME7. For some reason I thought the thread title said mk4 tdi rather than mk4 gti
    Even so, what tools do you guys use to read / write ME7
    May 2010
    jarvis bay
    wat power out put am i looking at with the k04 fitted, with new fuel pump injectors, front mount 2.5inch turbo back exsaust, cold air intake, plus possibly looking at doing the ignition system aswell coils etc ...wat is safe boost pressure on the stock internals on the 1.8t?? im already running 15psi. was looking at going to round 18psi..i am a complete hater of manaul boost controllers electric ones arent much better id prefer to set the boost pressure in the ecu itself is this possibly without ending up with heaps of "gain" or boost spiking ....
    p.s thanx for all the help guys really appreciate all the input , u can probly tell i know nothing on euros ive only ever owned jap cars in the past thanx
