![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
brad
I don't know enough about it to debate it, which is why I put question marks.
Can it achieve 110% duty cycle if it's a mechanical pump? eg: the pump is designed to output xL/min at yrpm with the rpm being anywhere from (say) 500 to 6000 (redline ignition cut). This output is regulated / reduced by the built in high pressure fuel regulator but you still can't exceed the mechanical output with the electronic regulator - only reduce it?
or... How would you achieve more than 100% (unless you're a footballer, because they put out 110% all the time)
