Results 1 to 7 of 7
Thread: Torque Ratings
    Feb 2006
    Camberwell, Victoria
    Torque Ratings
    When you're given torque rating for certain things..
    Head Bolts, Conrod Caps, Camshaft caps...
    Is it bad if you over torque??
    I have a torque wrench, but 15nm for camshaft caps seems fairly loose...
    Will that rattle loose??
    Feb 2006
    Bump........
    Apr 2006
    Hobart,Tas
    No, stick with the readings. VW know more than anyone about what torque things should be and you should never stress studs or bolts otherwise they will come loose due to a stretch bolt/stud.
    For instance (and I apologise for this reference) air cooled motors with the 8m/m studs are only done to 18ft/lb each. Providing everything there is machined correctly they don't come loose. Cheers!
    brackie Guest
    Echo
    Absolutely stay with the manufacturer's torque specs. Ever heard of "bearing crush"?
    The only time I ignore VW is when tightening the cam sprocket on a diesel as it's a taper fit and there are many tales of it loosening with disastrous results on an interference motor. My son's lovely and rare Audi 100 diesel suffered this fate.
    Just to reassure you & for interest sake.
    All BMW camshaft bearing caps with a M7 thread are torque'd up to 14nM incl. all the motorsport vehicles. M3's, M5's etc.
    If thats what the manufacturer recommend's, then that's what I'd do it to.
    Oct 2005
    Dandenong North, Vic
    According to my Bentley manual, it says
    Camshaft bearing caps to cylinder head (nut)
    8v 20nm (15ft lb)
    16v 15nm (11ft lb)
    Apr 2006
    Hobart,Tas
    16 valvers only have 7m/m studs and they do snap.
    8 valvers are 8 m/m studs Cheers
Similar Threads
  1. Vans sold in NSW & VIC down on HP & Torque
    By jets in forum Transporter, Multivan, Caravelle, Kombi
    Last Post: 02-03-2007, 05:55 AM
  2. Torque
    By shaneth in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 19-01-2007, 08:29 AM
  3. Little torque steer concern.
    By Eddy in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 24-11-2006, 09:36 AM
  4. Torque setting for bottom end
    By 82cab in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 10-11-2005, 09:55 AM
  5. 1.5 head bolts torque specs?
    By hill billy in forum Diesels
    Last Post: 23-09-2005, 02:17 PM
