lif you want ITB's for the sounds and "cool" factor, which is a good enough reason (if you've got the cash) you may as well get bike carbs an 8V!
really. bike carbs even with a custom manifold, will be a hell of alot cheaper than ITB's + ECU + tuning. Also about half as much as (brand new) twin DCOE's.
Ultimately twin DCOE's aren't the most effective/effiecient way of making power, but shure, they sound good!
IMO (and correct me if my figures are wrong, Tim) but and 2.0L 8V with bike carbs (quad 40mm, sim to twin 40mm DCOE) with a decent cam (around the 276 region) a bit of head work, (read: more flow) and a few other bits and pieces, exhaust etc. and a proper tuning, and you could be looking at 130kw @ flywheel.
140HP in a 900(or less) kg car, for street purposes (mainly) perfect. you don't need more than that.
The money you save over buying a 16V and ITB, ECU etc, you can spend on actually getting better parts for an 8V (pistons, rods, machine work etc) (that's where the extra 20 or so kw come in)
Anyways, that's just my opinion. My next petrol engine will be pretty similar, except k-jet, "stage 1" headwork, lightened flywheel, 276 cam, balanced bottom and prolly a 1.8. I'm hoping for 100HP. That'll be enough for me![]()
