EDIT:
On second thoughts, post your questions here, they will be answered and the info will be added. Please, no chit chat though.
This is a thread for technical information and terms automotive related. And more specifically, technical info and terms for Volkswagen vehicles.
Engine and drivetrain terms
8v- The term commonly used to describe an engine with a valvetrain containing 8 valves. In most cases, this will be a 4 cylinder, ie: 2 valves per cylinder. 1 inlet, 1 exhaust.
16v- The term commonly used to describe an engine with a valvetrain containing 16 valves. In most cases, this will be a 4 cylinder, ie: 4 valves per cylinder. 2 inlet, 2 exhaust.
DOHC- Double Over Head Cam. This is the term used to describe an engine with 2 camshafts in the head, operated directly over the valves. One camshaft operates the inlet valve train, the other operates the exhaust valves. DOHC setups are mainly used in multi valve engines. In the case of the VR6 engine, due to the staggered bores, the two camshafts actually operate the inlet AND exhaust valves for the front or rear cylinders.
Multi Valve- This term describes an engine that has more than 1 inlet and/or exhaust valve per cylinder. Eg, a 16v, 4 cylinder engine.
VR6- Vee Reihe Sechs. Which, when translated to English, means Vee Straight Six.
Common Abbreviations
VAG- Commonly referred to as "Volkswagen Audi Group" or "Volkswagen Automotive Group". The correct term is actually "Volkswagen aktiensgesellschaft", which means "Volkswagen Company Incorporated".
This will do for the moment, i have just written this in to kick this thread off, and I will add more later on.
If you have more useful terms to add, please PM either me, or a moderator and the information will be added. Please do not them in this thread as i would like it to stay as uncluttered as possible, and keep the information restricted to a minimal number of posts.
EDIT:
VAG = ? (character limit)
No more running wild...
volkswagen aktiengesellschaft
2x Caddy, 1x Ducato
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
Volkswagen LTD pretty much. like a public company with limited liability. quite similar to GmbH
87' MK2 GTI
13' MK7 TDI
Yeah i served my apprenticeship with VAG and obvious answer would be Volkswagen Audi Group but it is in actual fact not. The correct answer is Volkswagen aktiensgesellschaft which means company incorporated. You will find if you look at the other big brands like BMW, Merc and Porsche they are in actual fact BMW AG , Mercedes-Benz AG and Porsche AG and V AG.
Hope this clarifys , i ceratinly had it drummed into me in the regimental days at dub.
JMAc
Alba European
