DNA Tuning (Australia)
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 53
Thread: Any tune out there without bench flash
    Sydney,NSW
    I want a TDI tune but don't want to get the ecu bench flashed. I have the new ecu that doesn't like obd flash
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by cru22z View Post
    Well Alientech just released a whole lot of new MK6 diesel tunes on OBD that were previously bench, and I currently have "test" OBD tunes for cars like the GTD and bluemotions. Just a matter of time.....
    Nov 2009
    Quote Originally Posted by Greg Roles View Post
    Hey Greg, What sort of gains can be had on a MK6 GTD? With or without down pipe?
    Volvo S60 RD T6
    Jan 2008
    Sunshine Coast
    Alientech is just the reading and writing tools Viezu, and a lot of tuning companies use at a dealer level, it's basically just an old style modem. The software lets you select a particular car, and all it does is adjust the baud rate amongst other things to "talk" to the car.
    These guys crack a car, by working out a route into the programming gate all ECU "chips" have. That is not always so easy, hence some cars remain bench tune, where you have to connect directly to the ECU board, or tuners have to open it up and enable OBD physically - which is the same lid opening risky affair.
    The MK6 diesels are limited by the DPF for the time being, so you will get a mid level tune from anyone. On the GTD you will see approx 35hp and 75 nm. Without a DPF you would be able to push more like 45hp and 100 nm plus, but this sort of tune with a DPF in place will prematurely clog the DPF. I currently run a crazy 120nm plus race tune, and my DPF cycle has dropped from approx 800k between regents to 400. It's not something released to the public because of this big downside.
    You can't legally put a down pipe on a DPF equipped car YET, as until I perfect it, there is no high flow DPF option available from anyone. You can delete the DPF, I don't offer that given the illegal nature and the other downsides, but currently that is your only "dump pipe" option. VERY obvious mod to risk your new car warranty though, and again not something I would recommend.
    Nov 2009
    Cheers Greg, never really understood what the dpf was just googled it and now all is good. Does this apply to the MK5 as well?
    Volvo S60 RD T6
    Jan 2008
    Sunshine Coast
    Only the 125kw versions.
    Adelaide hills, SA
    Quote Originally Posted by thezoneR32 View Post
    The 103kW Mk5 Golfs incl. 1.9TDI Mk5 don't have the DPF.
    Sydney,NSW
    Where can I get info on this please??
    May 2007
    PM Sent...
    Sydney,NSW
    Man I wish someone can get this obd tune up and running on this md17 ecus without being bench flashed. I want more power!
