do you have all the parts and need someone to fit it up?
its really not all that difficult. virtually any exhaust shop can do it. if youre any good on the tools, then try it yourself.
Hi all
Just wondering what is the rough cost of installing a TBE to a Golf R?
And any one can recommend a fitter in Sydney that knows VW pretty well?
Thanks!
Its a couple of hours work so allow whatever rate the workshop charges for this ~$200 or so
.....you have to ( in no particular order)
remove narrow band 02 sensor
remove wideband o2 sensor
remove intake
remove rear muffler
remove bracing and heat shields
remove tailshaft
remove stock dump pipe
to quote Gregory's 'installation is the reverse of the removal procedure"
Most places will be closed over the Xmas break though
