![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Lucas_R
Yes the engine cover is a mission isn't it. To get the rear rubber mounts back in, insert them into the engine cover (all 4 of them - use a flat blade screwdriver to help insert them) and then they will just pop back onto the mounts when you fit the engine cover back on. A little bit of Vasoline or grease will help then slide back on).
No haven't got my downpipe/cat yet......still saving.
After much hassle ended up getting the engine cover back on, but I think I screwed something up when I was doing it. Im getting a ticking sound coming out of the engine bay whenever I take off or change direction quickly, feels like something is loose or flexing thus making the sound. I also started noticing that when the car is in Park and I take my foot of the brake I get a loud click that seems to be coming out of the gear lever. Not sure if they had something to do with installing the air filter but seems to have started after doing it.
Candy White Golf R DSG MDI Bluetooth & Bluefin installed!
