I have a 1.8TSI with Bluefin. The only issue I had with it was 2 big detonations immediatly after install as I got up it too fast going up the hill out of Maianbar. After that it was sweet as a nut - better than the OEM map.
You still haven't said how many kilometres the car has done......?
IIRC, the Bluefin handheld device has some limited logging or error reading capabilities - possibly even the ability to reset your CEL. What happens sometimes is that the ECU can be logging error codes but you won't get a CEL until a predetermined number is reached (say 50 error codes = CEL).
Don't go changing parts at random without a proper diagnosis. Also, I wouldn't get too carried away in public as you will probably have to put it back to stock to get the fault fixed ![Wink](https://www.vwwatercooled.com.au/forums/images/smilies/icon_wink.gif)
What part of Sydney are you in? You can borrow my VCDS cable if you'd like.
