I have a 1.8TSI with Bluefin. The only issue I had with it was 2 big detonations immediatly after install as I got up it too fast going up the hill out of Maianbar. After that it was sweet as a nut - better than the OEM map.
You still haven't said how many kilometres the car has done......?
IIRC, the Bluefin handheld device has some limited logging or error reading capabilities - possibly even the ability to reset your CEL. What happens sometimes is that the ECU can be logging error codes but you won't get a CEL until a predetermined number is reached (say 50 error codes = CEL).
Don't go changing parts at random without a proper diagnosis. Also, I wouldn't get too carried away in public as you will probably have to put it back to stock to get the fault fixed
What part of Sydney are you in? You can borrow my VCDS cable if you'd like.
