Originally Posted by
lenojd
sounds 'a little' similar to my situation
put a bluefin stage 1 tune onto my MKV GTI and after about 2.5-5k km the following symptoms suddenly happened:
- revs continue to climb/jump rather than dropping when engaging clutch to change gears
- cruise control doesnt work
- surges up to around 3000rpm
- very rough & jerky through the rev change and gear changes
Problem is even after returning to stock, all symptoms still exist. Have had clutch switch & throttle body replaced which did not fix the issue.
Contacted Bluefin who said since the problem still exists after returning to stock, they don't believe it is tune related.
Currently testing the ECU for a possible ECU issue which I hope it is not :s
