![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Reedy
.......... I need plenty of power and put my foot down there is a small shudder like there is not enough fuel to make the power. This is only now and again and mainly in 3rd gear and above. The lack of power is like when you have a bad o2 sensor but it only lasts for a second and then the power comes in. Off to get some data logging done just to make sure the car is ok for my own piece of mind.
More updates to come.
Ps any idea how the bluefin works as a data logger?
did you have your traction control on or off? if on, that would be the traction system interfering (for safety vw says?).
i doubt the bluefin unit can work as a data logger, if yes then i would have used mine often, but i could be wrong ![Sticky out tounge](https://www.vwwatercooled.com.au/forums/images/smilies/tongue.png)
i am on bluefin stage 2 (older file) for almost 2 years / 20,000km now and it has been fine. plus superchips uk does get back pretty quick when you contact them for a new file (during uk daytime).
MINI Cooper S Clubman - FWD
