I've debated about doing it many times, as I'm sure most k-jet owners would have, would be the same as turboing a k-jet, you can use bits from an old audi turbo k-jet to use on your system to get the desired results. I think they're limited in the final power output though, something like 180hp but then there's add on injector kits that can boost power further. Have even been told you can run a fuel distributor of cars that had more cylinders ie a volvo or a benz, and running up to 8 injectors.....
