Depends on the type of charger. And weather you run the carbs before or after the charger.
Roots style chargers IE toyota 4agze you can run air and fuel through the charger as they're fairly robust and run fairly large clearances. The old super charged bentleys and alfas run roots style chargers and generally twin SU type carbs. With the carbs before the charger.
When people run the chager before the carbs you need to get well sealed carbs. IE dellortos which were designed with this in mind (basically a copy of webbers but with sealing to run boost through the carbs).
