is that a toyota 4AGZE charger?
Looks tiny, might add restriction higher in your rev range.
What do you guys think? i have a lil supercharger lying around was going to see if i should fit her up... looks like i could moun t it fairly easy and get some pipes made up at the local exhaust shop... or even buy the bend and weld them up myself...
i also have a little intercooler so go with it will get pics of it soon.
here are some pics of the charger and where i though would be a good spot for it.
the crank shaft pulley already has the end made up to drive a belt and the teeth on the supercharger fit that...also have the belt so i just have to make up some mounts for the charger.
mk2 GTi 16v
Corrado G60
good idea or not so good idea?
or better of selling it and turboing it?
You'll have to upgrade your K-Jet with increase fuel pressure & boost sensitve warm up regulator.
You'll also have to fit a timing retard for you ignition!
I don't get it.
If you run K-jet with any forced induction the piping has to run from the airflap to the unit, whether it is a turbo & supercharger & then onto the intercooler (if fitted) & then the throttle body.
K-Jet system pressure should also be 5bar & control pressure should be from 1.2bar (cold) to 2.8 bar (hot) Approx. figure's
