Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 91
Thread: Supercharged mk1
  1. #51
    Eastern suburbs of Melb
    Quote Originally Posted by Grunmk1 View Post
    No worries. I had an AGG 2.0l which was EFI already and I used a microtech ECU. I'm not sure how to set it up with k-jet, it would make things trickier I'd imagine but its not impossible. Good luck though, it definitely gives you a good power boost!
    ok cool!
    well there is a first for everything! hope it works
    one last q...where do i run the bov? between the ic and the throttle body?
  2. #52
    Gosford Central Coast NSW
    yeah, usually close to the throttle body between the air mover and the throttle.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  3. #53
    ok. i learn more and more everyday
  4. #54
    Jan 2006
    Heres a pic of my old setup, you can see the bov (or bypass valve in this case) on the pipe-work heading from the intercooler to the throttle body. Just one thing, with a blower if you say back off at 5000rpm the pressure doesn't just vent in a split second and give a little whoosh like on a turbo, it just keeps pumping out with a massive roar. It is REALLY loud. With this type of blower there are ways to get around this by activating the clutch on the blower to shut it off when the throttle is closed but I never found a way I was entirely happy with because when you'd stand on it again there was a slight delay before the blower clutch disengaged again and the power came back on. I had some ideas on things to try to get around this problem.
  5. #55
    ok yeh i understand that! very nice. was it fun to drive?
  6. #56
    Jan 2006
    Yes it was fun. I had the supercharger clutch wired up to a switch on the dash so I could literally turn the blower on mad-max style. The rest of the time I could just drive around normally and quietly and the blower would just free-spin under vacuum. When I flicked the switch I would get an instant extra 45-odd kw and a great whining sound from the engine and the exhaust note would almost double, it was great fun.
  7. #57
    why not exhaust the BOV through a hose back into the feed pipe into the blower?
    '99 A4 Quattro 1.8T
  8. #58
    thats nuts! that what i was saying to dad i could just wire the switch up under the dash so that if there were cops i would just flick it off how long did it take you to do? did you move the alternator under it? i was thinking of doing the opposite...and having the sc under the alternator...so its at least a lilbit hidden...but i think im going to have to get a 2.0lt with a computer because the k-jet gets in the way massively! is there a small intercooler tucked up the front on the right?
  9. #59
    Jan 2008
    Cremorne, Melbourne
    Quote Originally Posted by thestu View Post
    sweeeet! thanks for the advice. i'm trying to find some for sale now
    have a look in the classifieds of www.boostcruising.com. there are usually a heap of forced induction parts available from there all from australia.
    happy hunting!
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
  10. #60
    Jan 2006
    I actually did do that, I had to when I went for the engineers certificate. It was still really loud because i was just using a pod filter so it didn't muffle the sound that much. What I needed to do was run either a massive bov or a few normal sized ones. I was investigating large solenoid activated bypass valves at the time which would have had the added bonus of creating a less restrictive intake path for the motor when the supercharger was turned off. The other thing that would have helped is venting into a large chamber of some sort and then into the intake.
