careful stu - your charger ID
stu, that charger you have is not a toyota model.
the toyota SC-12 (1200CC displacement per rev) and the SC-14 (1400CC disp/rev) are much larger (and made by toyota).
the supercharger you have posted pictures of is, as mollins pointed out, the AISIN AMR300. this supercharger is only 300CC displacement, and hence you will need to run a very large overdrive to make any boost (or even keep up with atmospheric pressure).
AISIN is part of FUJI heavy industries - who make subaru. the 'charger is from a 600cc viveo which was sold only in japan. there are a few kicking around - i once bought one on ebay.
since its got such a small displacement, it is unlikely to be of any use to you (unless you plan on downgrading to a small block 1.1l engine or something)
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
