Superchargers don't just run one specific boost pressure.. It depends on the rotating speed (which in turn determines the output volume) compared to the CFM the engine will draw.
It would be a bit of a guess at what boost pressure it would run at 1:1 or with overdrive, but the manufacturer should be able to give you a ballpark figure for you engine capacity. If worse comes to worst you could underdrive it. I've seen that done a number of times before with good results.
PS.. I like superchargers..Glad to see someone not going the shmurbo route.![]()
