DNA Tuning (Australia)
Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 91
Thread: Supercharged mk1
  1. #31
    Jul 2005
    Melbourne, Williamstown
    Quote Originally Posted by thestu View Post
    so if its not i might get a harop supercharger!!
    Might not be a good idea, might put out too much boost for the Kjet to handle, I think a toybota charger is the go for your application. Cheap/reliable/etc
    mk2 GTi 16v
    Corrado G60
  2. #32
    Jun 2006
    Orange NSW
    Quote Originally Posted by ausgolfer View Post
    Superchargers don't just run one specific boost pressure.. It depends on the rotating speed (which in turn determines the output volume) compared to the CFM the engine will draw.
    It would be a bit of a guess at what boost pressure it would run at 1:1 or with overdrive, but the manufacturer should be able to give you a ballpark figure for you engine capacity. If worse comes to worst you could underdrive it. I've seen that done a number of times before with good results.
    PS.. I like superchargers..Glad to see someone not going the shmurbo route.
  3. #33
    Jun 2006
    Orange NSW
    I made up mounts to fit a similar but larger toyota supercharger off a 2l engine on my 16v and calculated that running it at 2.2 times crank speed would acheive 1 bar or 14.7 psi boost. I still have the mounts for it! But i sold the charger... I have seen a very impressive yet simple setup using a charger directly ontop of a modified inlet manifold with a downdraft 40mm webber on it. The drive belt was run off the cam gear with another gear mounted to the front of the cam gear. With 7psi it made 150hp on a 1.8 with standard internals. Go for it!
  4. #34
    Quote Originally Posted by twin eng, twin turbs View Post
    I seen a similar setup like this using K-Jet.
    Was available as a kit. The blower looked like a very small 6/71.
    I'm bugger if I can remember the name!
  5. #35
    Update!!!
    Was a Autotech Magnacharger kit!!!!
    http://forums.vwvortex.com/zerothread?id=3203070
  6. #36
    Jun 2006
    Orange NSW
    Quote Originally Posted by golfworx View Post
    Update!!!
    I've got the article on it at the workshop still.. I'll scan it and post it if you like.
  7. #37
    Eastern suburbs of Melb
    ok so what i'm going to do is whip out what parts i have (and the charger i have(...mount the charger and get it running with the motor...belts hooked up and all.
    get an intercooler made up...spewing i missed out on stu's one. then measure up where all the pipes must lead and hook them up.
    would it be better to run solid pipes or flexible ones? by my calculations this sc should run at 5-6psi...and hopefully make a difference
  8. #38
    Jun 2006
    Orange NSW
    You should get about 20 to 30hp from that i'm guessing, with good mid range and great bottom end.
    Flexable or solid.. It really doesn't matter that much, however you are better off running solid tube as much as you can, with a few flexable joints where you need them. That eliminates a lot of the chances of getting leaks.
  9. #39
    Jul 2005
    a newer more efficient charger than a an old toyota roots style will most likely give more boost than a Kjet turbo system can take....unless you shell out for porsche kjet injection parts.
    mk2 GTi 16v
    Corrado G60
  10. #40
    Jun 2006
    Orange NSW
    if you use a more efficient puffer, that just means you can use a smaller one or decrease the overdrive to match the boost pressure you want.
