hmmmmm, so if i were to try this with a carb setup i could just go ,
Carb --> S/C --> intake manifold/motor
Right?
with a setup like this i wouldnt be able to have a IC due to the fuel being put in the mix before its heated in the S/C. Also there would be no way i could run a blow off.
So who has done/seen a setup like this work well?
Im expecting to see alot more supercharged Mk1's after this thread is done.
~~~~____~~~~~~~~~_\_____
~~~ /_|__\__~~~~~~ / //__|__\___
____( )|__( ) ]_MKI ___[(' )__|___( ) ]_MKIV__
