DNA Tuning (Australia)
Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 91
Thread: Supercharged mk1
    Quote Originally Posted by golfworx View Post
    The piping run's from the K-jet gear, to the supercharger & then onto the throttle body.
    Read it again. Carefully!
    Air comes in through the air filter, through the K-Jet airflap, onto the inlet of the supercharger, ou tof the sc & onto the throttle body/intake manifold
    Eastern suburbs of Melb
    ooooooo i get it now and if you have the intercooler that goes before the sc?
    so what would i have to modify other than the piping?
    intercooler after sc
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    like this , very quick pic
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Quote Originally Posted by DVR68U View Post
    ok i get it! learn stuff new everyday! i'm new to all this sc and turbo stuff.
    with such a small supercharger should i bother with the interchiller?
    Jul 2005
    Melbourne, Williamstown
    well the toyota runs one with that charger...... but might be able to get away with it. Still got the issue with the changing of the fuel and ignition stuff to handle boost.
    mk2 GTi 16v
    Corrado G60
    Quote Originally Posted by ausgolfer View Post
    yeh true. so what would i change? i'm thinking of going electronic ignition if that would help.
    so like this....
    but would i need a BOV or a valve of some sort...because when the throttle snaps shut where does the vacuum go?
    yeah like that pic, ,you can put the bov after the intercooler. or maybe even before it . and it will still be under boost when the throttle shuts .
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Nov 2005
    newcastle
    Quote Originally Posted by thestu View Post
    its off a 4AGZE motor yeh. its fair small can run up to 6psi i think. thats ok high revas wouldn't make much power anyway...stop making power about 5,800
    anyway
    Are you sure its from a 4agze motor? that looks like the smaller 300cc AISIN from a subaru vivio. check for dimensions here
    TDI mk1 on the road!!
