Page 1 of 10 123 ... LastLast
Results 1 to 10 of 91
Thread: Supercharged mk1
    Eastern suburbs of Melb
    Supercharged mk1
    What do you guys think? i have a lil supercharger lying around was going to see if i should fit her up... looks like i could moun t it fairly easy and get some pipes made up at the local exhaust shop... or even buy the bend and weld them up myself...
    i also have a little intercooler so go with it will get pics of it soon.
    here are some pics of the charger and where i though would be a good spot for it.
    the crank shaft pulley already has the end made up to drive a belt and the teeth on the supercharger fit that...also have the belt so i just have to make up some mounts for the charger.
    Jul 2005
    Melbourne, Williamstown
    is that a toyota 4AGZE charger?
    Looks tiny, might add restriction higher in your rev range.
    mk2 GTi 16v
    Corrado G60
    Quote Originally Posted by ausgolfer View Post
    its off a 4AGZE motor yeh. its fair small can run up to 6psi i think. thats ok high revas wouldn't make much power anyway...stop making power about 5,800
    anyway
    good idea or not so good idea?
    or better of selling it and turboing it?
    You'll have to upgrade your K-Jet with increase fuel pressure & boost sensitve warm up regulator.
    You'll also have to fit a timing retard for you ignition!
    Quote Originally Posted by golfworx View Post
    i wouldn't run the piping through the box i would have it split just after it leaves the box.
    I dont understand about the fuel side? its already running at 8psi...from the k-jet pump. from what i understand
    Quote Originally Posted by thestu View Post
    I don't get it.
    If you run K-jet with any forced induction the piping has to run from the airflap to the unit, whether it is a turbo & supercharger & then onto the intercooler (if fitted) & then the throttle body.
    K-Jet system pressure should also be 5bar & control pressure should be from 1.2bar (cold) to 2.8 bar (hot) Approx. figure's
    I don't get it.
    oooo...
    so it doesn't run from the charger to the throttle body and the air box just draws air?
    hang on i will draw a pic of what is in my head!
    oooo...
    Yeh.
    The piping run's from the K-jet gear, to the supercharger & then onto the throttle body.
    But the K-jet still need's boost reference to supply the right amount of fuel.
    this is what im thinking in my head...
    or does it have to go like this?
