DNA Tuning (Australia)
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Strange Behaviour
    Jan 2013
    Strange Behaviour
    Hi I'm a newbie but have been looking at these forums for a while.
    I had my Mk6 GTI tuned recently and it's not exactly behaving itself.
    Anyway thought I'd post some pics of some logs and see if anyone has any idea whether it's a problem with the tune or hardware.
    First one's shows the actual boost vs requested boost @ full throttle 2nd gear
    Second is moderate acceleration with fixed throttle position running with DSG in "D". Short-shift in 1st, 2nd gear to 3,000RPM and then cruising. Note that the boost drops off after 2,000RPM which results in loss of power.
    Anyway interested in your thoughts and yes I will be going back to the tuner but want my ducks in a row first.
    You need to do logs in 3rd, you get a much better idea of what's happening. What do you mean by not behaving itself?
    Back to the tuner is the way to go. Boost leaks are not uncommon.
    Jan 2013
    Thanks Gavin. OK 3rd gear but then I'll have to wait until I can find a nice bit of highway (110km/hr) zone to try that out
    Boost comes on way too late - 3,500RPM. I would have thought that the requested and actual boost would have followed each other a lot more closely until the K03 runs out of puff.
    Yep just thought that I'm eventually getting boost that maybe it's something else.
    Thanks for your suggestions.
    Quote Originally Posted by pinkgti View Post
    You'll get a better look at the boost on a 3rd gear pull. A rip up to 5000 would probably give enough info, it's going to die off any way but assuming your tune is from a known source, they won't be requesting more boost than the turbo can make low down. Otherwise you could spend a lifetime chasing non-existent leaks.
    As a mild comparison my Polo makes full boost by 2800 and the S3 by about 3200.
    Jan 2013
    Yeah not too concerned about the 5,000-6,000 at the moment - mainly bottom end as that's what I use 99% of the time anyway.
    The other thing is under moderate accelerate the power delivery isn't smooth - kind of surges. Between 2,000-3,000RPM is a flat spot.
    So do you think it might be a problem with the turbo if it's not spooling up fast enough? Or maybe just a stuffed up tune.
    Gosford Central Coast NSW
    I would check with the tuner ASAP, but if it was a hardware problem it could be an exhaust leak between turbo and engine (manifold somewhere) or perhaps the wastegate is not closing properly.
    Antoher thing to consider might be foreign object damage of the turbocharger compressor wheel.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jan 2013
    Yeah talking to the tuner but just logistically a challenge so trying to eliminate possibilities a the moment. What's the best way to check for an exhaust leak? and waste gate?
    Car is only 18 months old, but I guess anything is possible.
    Another thing to consider might be foreign object damage of the turbocharger compressor wheel.
    Is that easy to check?
    I'd say don't look too deep just yet. There's every chance of a boost leak. It may take 10 PSI to cause the leak and it may not leak at a fixed rate.
    Definitely speak to the mystery tuner
    Jan 2013
    OK mystery tuner it is. Just tryingto get a logical explanation for how it's driving.
    Jan 2013
    Going to remove my ECU and get it sent off for reflashing - car is going to be off the road for a few days but hopefully a new tune file will fix the issue (though if it's a boost leak we're back to square 1).
    Will post back once I have a new tune file in the car.
