DNA Tuning (Australia)
Results 1 to 10 of 12
Thread: Stock, lightened aluminium or lightened steel Flywheels ?
    Oct 2005
    Dandenong North, Vic
    Anybody know what advantages/disadvantages with stock, light steel or light aluminium flywheels ?
    20v kit car Guest
    FYI on my ABF motorsport engine it uses a lightened steel job.....works a treat.....all the other pulley's are alloy though cheers steve
    Nov 2005
    abf motor sport?
    what engine is that?
    MY16 MKVIIR - Option: Folded rear seats mode.
    MKI....#14....lost count.
    Golfwise Guest
    Steve has a VW motorsport ABF amongst his collection of goodies.
    Lucky duck
    Oct 2005
    Im replacing the clutch on the G60 and I dont know keep the stock or put a light flywheel (steel or alloy) with out knowing the ads/dis-ads. Anybody know ?
    20v kit car Guest
    basic advantage of a lightened flywheel is to allow a quicker rev....less weight to push around therefore more hp for the right foot to use..this is it basically....alloy will have a steel face as the pressure plate/ clutch plate will I thought mince one pretty quick.....disadvantage is the thinner the flywheel the quicker it heats up ..faster wear rate....I hope it makes a bit of sense...oh yer less mass at the flywheel causes hills to be felt a little earlier
    Aug 2005
    Quote Originally Posted by aussieg60
    The G60 flywheel is exactly the same as the ABF one. It weighs about 22lbs and is stupidly heavy.
    I've had mine lobbed back to 12.5lbs. Make sure someone reputable does it, though, as if it's imbalanced, you're motor will go up **** creek pretty quick.
    If the material is removed from the right place, it will mean the factory TDC mark is cut off, though, so MAKE SURE IT IS MARKED BACK ON AND NOT WITH A BLOODY TEXTA!!!!!!
    here's a pic of mine:
    Oct 2005
    I was thinking of a fidanza or autotech flywheel. Anybody know about these types ?
    Golfwise Guest
    hey Valver does mum know that flywheel is on her good chair,
    tut tut !
    Aug 2005
    Quote Originally Posted by Golfwise
    tut tut !
    I've taken over her entire house and live there more than my own until the car is done!!
    At one stage, I had body panels in 5 different rooms :twisted:
    Even now, both her sheds and garage are full up
