Results 1 to 5 of 5
Thread: Standalone Engine Management
    Jul 2007
    Rowville Melbourne
    Just wondering if anyone can recommend a Standalone Engine Management system that is really easy to set up and use in a mk1 Golf with 1.8t?
    Does anyone have any experience with Lugtronics? ive found they have a fairly plug and play kind of system and would be keen to use it if its a s good as it sounds. From the way the describe it its just an ECU that plugs into the stock harnes with an adapter, you just have to run a vacuum line to the ecu which has a MAP sender in it.
    Would local tuners be able to change the maps and generally be able to tune it?
    I have no idea about SEMs!
    please guide me!
    Thanks!
    -Steve
    Not many plug and play unless you check qpeng maybe.
    Custom-Code and defeat the immobiliser in a standard ME3.8 ecu allowing you to run it in the car and retain the diagnostics if you want to.
    Jul 2007
    Rowville Melbourne
    Whats the go with running the standard ecu? does everything on the dash still work, like all the lights and whatnot? i thought you needed mk4 dash to run stock management or is that the immobilizer defeat you mean?
    I'd looked into qpeng quite a bit but i wasnt comfortable with how little service i could get for it here and i hear the interface isnt very convenient. Wasnt sure how easy it was to get someone to fix should something go wrong!
    You can run the MK1 clocks with the mk4 stuff for the most part. Alternator light, oil pressure etc. Just a case of connecting the MK4 loom to the respective mk1 wires.
    Not 100% sure if you need a box to make the rev counter work. Also the speedo on the MK4 is electronic but that may take a cable to the MK1 clocks.
    I haven't personally done the conversion but using the MK4 ECU would be a priority to save all the time wiring in the standalone. Off the shelf maps for Phase 1 and 2 hardware that are guaranteed to work. Factory driveability and cold start.
    Jul 2007
    Rowville Melbourne
    hmm you have PM!
    the ECU i would be using would be out of like and audi A4 or soimething i think. that ok?
    -steve
