Results 1 to 10 of 12
Thread: Stage 2 118 TSI Upgrade
    Oct 2014
    So, after convincing myself it was all too hard and expensive to bother squeezing another few kW and Nm out of the 1.4 with a downpipe, I came across a turbo back, non resonated, Milltek system with sports cat dirt cheap, put a bid on it and am now the new owner.
    I'm tossing up a REVO stage 2 or Revlimit stage 2 or even 2+ at this point and have asked for some quotes. I know Guy H looked at this back in 2011 and even had some APR maps for it but given the recent changes by APR LLC I guess that's all out the window.
    For those that are interested, I'll try and document the install and heat shielding at the downpipe end and get the car on a dyno for the Stage 2 tune results.
    May 2007
    Quote Originally Posted by Mk R View Post
    Mk R - sound great mate! Keen to hear your results!!!
    Oct 2014
    Quote Originally Posted by ope126 View Post
    Thanks Ope126! I'm getting excited mate. Also saw this on fleabay this week...
    1.4TSI 200 cel Downpipe for ~$700 delivered to AUS
    Downpipe Exhaust 64mm With CAT S S FOR VW 1 4 TSI Golf 5 6 Scirocco NEW Beetle | eBay
    Might be worth chucking on the watch list in case the dollar keeps getting stronger. I was originally looking at this with just a step down to the stock exhaust.
    Jul 2011
    Epping, NSW
    Keen to see how it goes with stage 2!
    Sent from my E6653 using Tapatalk
    '09 mk5 Jetta 118TSI
    '11 C7 A6 3.0TDI
    '11 B8 A4 3.0TDI - RIP
    May 2007
    Any updates Mk R?
    Oct 2014
    Any updates Mk R?
    Away for work this month, going to be installed and tuned mid June at this point so will have the first dyno graph of the current stage 1 setup before then. Looking forward to seeing it compared to the recent dyno session from another 118TSI owner here recently!
    Dec 2006
    Kilsyth, VIC
    I was always told that the issues were around heatshields in the stock unit that would need to be replicated in an aftermarket unit... give that doesn't have them is that an issue?? Is it different in the Scirocco vs the Golf?
    Oct 2014
    Quote Originally Posted by The_Hawk View Post
    It's still a concern, the engine bays are very similar if not the same. Everything is quite close together down there but the new downpipe is actually slimmer in total diameter (at the wide point where some of the fluid hoses and wire pass it) so i'm proposing to do a downpipe wrap, install some dimpled heat shielding from Supercheap to section off the small pipework and possibly cover the heat wrap in a foil layer. If that still presents heat issues to the hoses i'll wrap them too.
    As you can see here, there's an intercooler pipe down there too that i might try and insulate as well but what that looks like will depend on how much of a gap there is.
    Attached Thumbnails Attached Thumbnails Stage 2 118 TSI Upgrade-14twin-png
    Oct 2014
    So after a bit over a year, I've finally got around to putting the exhaust and fresh turbo on my Golf and getting the stage 2 map installed. I must apologise for the delay, I got a mortgage and some orthodontics in the mean time and it put the brakes on more fun things like this. I figure these cars are worth so little now that its going to stay with me as a fun daily driver until the wheels fall off.
    First impressions are:
    - Much smoother power curve
    - Longer harder push past 4000 RPM
    - Feels like the power is on tap sooner, also feels a little stronger throughout
    - Obviously a boomy exhaust note from the currently non-resonated exhaust which now has some pop and the occasional crackle on gear change which is a nice novelty for someone with a 6 speed manual
    - Slight turbo flutter like a pigeon when coming off the gas under low acceleration
    No CEL errors yet and it's had a few good full boost pulls up hills and on highway.
    One phantom boost limp (restricted to 15 PSI) after some "spirited" driving up a hill. That seems to clear itself aster a few minutes of quiet driving. Picked up an N249 error code after install so that might explain the flutter.
    Will post a few photos and a video of the sound if anyone is interested. Hope to put it on a dyno in the near future and see what it makes!
    Dec 2006
    Kilsyth, VIC
    Sounds great. I will be interested to see the photos when they are available!
