DNA Tuning (Australia)
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: "Sprintbooster" -- worth doing or a gimmicK?
    Aug 2012
    sydney, NSW
    worth doing or a gimmick?
    Sprint Booster
    Nov 2012
    QLD
    I do not believe they are a gimmick. They seem to do exactly as advertised.
    To be fair to sprintbooster it is mostly the users of their product who give it a bad name with claims like improved fuel economy, faster 0 to 100 times etc. I think as long as you realise the module is only doing what manufacturers often change deliberately between model change overs and between different trim specifications in order to achieve their desired "feel" to how the car's accelerator responds to input you will be fine. It cannot magically speed up the data transmission rate achievable between the accelerator pedal, the ECU and the throttle body and/or injectors...only adjusts the actual data being sent.
    Quote Originally Posted by seppo View Post
    Sprint Booster
    Some guys love it but if you have a decent tune on your car where the low end torque is maximised then really the device becomes almost pointless.
    The other thing I don't like is a device that messes with the stock DBW setup to me that opening up a point of failure that would otherwise not be there, luckily there are a few fail-safes to hopefully detect invalid values should say the SB start spitting out rubbish.
    save the $ and spend it on a tune then decide
    Apr 2010
    I've got one, it did what it promised, got rid of pedal lag. The increased pedal sensitivity along with the tuned supercharged engine makes for an impressive drive.
    Aug 2012
    sydney, NSW
    Quote Originally Posted by parso_rex View Post
    Ok. Thanks to all for the feedback. I can't really get much drive experience benefit from tuning because I have a v6. That's why I was curious about this alternative.
    May 2011
    Do it. You won't regret it.
    2007 Golf MKV 2.0 TDI DSG
    | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
    Adelaide hills, SA
    Yes, everyone who got the sprintbooster is happy with it, so don't go by what people who don't use it got to say about it.
    The real users reviews and comments are more valuable than the negative comments of those (incl. me) that didn't try it.
    ...or if you have a friend with the one fitted, ask himif you could try it.
    Jan 2012
    or save yourself hundred of dollars and push the throttle more
    Nov 2009
    Quote Originally Posted by zei20t View Post
    Not true. Ive had one on my R32 and on my modded gti and I wouldn't even drive down the road, without it being on all the time. It makes the car feel more 'alive" and in touch with your foot.
    Volvo S60 RD T6
    Apr 2010
    Same here, the way the car sounds and behaves with SprintBooster on it's highest setting is not reproduceable without the SB adapter & just pushing your foot down harder.
