DNA Tuning (Australia)
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: "Sprintbooster" -- worth doing or a gimmicK?
  1. #21
    Apr 2010
    I did get it after Stage 1. APR helped with DSG lag maybe about 20% whereas the SB made a much bigger difference. Much more instant response. Again the DSG tune has helped a lot, I can actually drive the car around safely without the SB. That said the SB is a third of the cost of the DSG tune, although the tune is much more beneficial for the 7 speed DSG's overall.
  2. #22
    Aug 2012
    sydney, NSW
    Quote Originally Posted by bennjamin View Post
    personally
    use the money that would of been spent of the sprint booster - and put that towards a stage 1 level tune for the car. Better response and more power for abit more cash.
    Unfortunately there is no beneficial tune for 3.6L 4motion.
  3. #23
    Has anyone noticed increase fuel consumption with a Sprintbooster, Pivot throttle controller, etc? I understand the theory behind it and driven other cars with it but I'm not 100% sold. I would imagine it would increase fuel consumption because say if you're driving at the speed limit say at 15% throttle position, would it be hard to replicate 15% with a throttle controller? as it might be at 20-25%?
    Generally, more power = more fuel. Seeing as the SB doesn't make your car faster just wondering if there were any negatives behind it
    MKV GTI Pirelli
  4. #24
    Mar 2012
    Sydney NSW
    Quote Originally Posted by seppo View Post
    You are right - this logic does not apply to all VWs
  5. #25
    Apr 2010
    Slightly more fuel usage, but's that's more a driver fault than the pedal. Even on the raciest setting I was surprised how easy it was to control the pedal in car parks, etc, it becomes more like a pressure switch - you get used to it (just like you get used to the very sensitive brake pedal compared to other cars).
  6. #26
    Jan 2012
    so why not save money and get used to the factory throttle pedal??
  7. #27
    Aug 2011
    vic
    does anybody know where to get the newest one cheaper? 300 seems a bit much, i thought they used to go for 250
  8. #28
    Apr 2010
    Because of the dangerous DSG lag in the 118TSI. You had to accelerate ~half a second before you actually wanted to move if you were to adapt. Slotting into traffic was near impossible even with all of that Stage 1 power.
    @vraptor 300+ has always been the going rate.
  9. #29
    Jan 2012
    With nearly everyone talking about using DSG equipped vehicles when using Sprintbooster which from what I can gather works quite well. How well do you think it would work on a manual 1.6 turbo (same as cooper s engine)? I should probably note I get maximum torque starting at 1400rpm.
    TRADED THE BEE'12 Sport Yellow/Black Citroen DS3 DSport THP155 6-spd manual w/ tech pack.
    SOLD '18 BMW 125i M-Sport | Sunset Orange | Sunroof | ZF 8-spd auto
    '23 MINI Countryman SE ALL4 PHEV | MINI Yours | BRG
  10. #30
    Apr 2010
    Not sure, guess the effect would possibly be a bit more simplistic. When researching before purchasing I noticed a few BMW owners complained about it making it harder to heel-toe when changing (of course only ~2% of people actually know how to do that).
    The other thing with my car is that by default when you first start accelerating the car behaves like a NA 1.4L car, and when you push down a little bit more the supercharger engages (there was a VW video demonstrating this somewhere), with the SB you effectively remove this "are you sure?" gap, resulting in instant boost.
