Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Ross-Tech Measuring blocks
    Aug 2009
    Melbourne, Vic
    And did you noticed that you can jump from saved excel table when you select a row with data straight to the graph and row you selected is a cursor. I like it I think that it is much better than graph mode from Ross-Tech.
    No I did not - thats neat. Another really worthwhile feature, is that dieselpower logview allows you to combine, superimpose and compare multiple test runs as I did here.
    Adelaide hills, SA
    Quote Originally Posted by logger View Post
    Also If you click on tabs with measured values at the bottom, corresponding line doesn't show in graph, so you can turn it on and off as you like.
    I go on diesepower.cz forum from time to time and have downloaded some good and many bad logs, just to have different examples. There is a lot of knowledge on that site too. They use the Logview when people who bought vag-com cable can't interpret test results of what they've measured, they post post the log and someone with the knowledge tell them if it's good or bad.
    It works well.
    Example: 81kW TDI kkk turbo, owner not sure about his MAF.
    MAF sensor tested with vag-com Log here look for Log1.CSV file (it stays there for 2 weeks than it's automatically deleted)
    Others replied him just clean MAF sensor (Pierburg) and all should be "ok".
    It looked like right answer to me.
