DNA Tuning (Australia)
Results 1 to 10 of 12
Thread: Ross-Tech Measuring blocks
    Ok, so I got my little blue cale off flea bay and downloaded the appropiate shareware version of the software and now I want to do some basic data logging to see how things are running.
    Before I dive head first into upgrading my turbo, I want to make sure everything is currently running all ok. I want to be looking at things such as MAF readings etc. I'm not a huge tech head when it comes to interpreting the read outs but I have google as my friend so i can compare variables against others.
    So, where do I start?
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Neil, with your ECU there's not the best selection of things to log. I log 05 14 and 15 for MAF and timing pull IIRC.
    On the ME7 ECUs like the Polo and TT etc, you can get MAF, boost and lambda which is probably the best selection.
    You also get engine speed too.
    Have a look at logworks 3 on google and download it. I'll send you over some of the logs I took of the A3 to check out. It'll be engine speed, boost and lambda.
    Dec 2007
    Melburg East VIC
    the shareware version doesn't log boost as far as i know (you can log up to block 25) and your gti probably doesn't hava a map sensor anyway (assuming 99 model - agu dbc). you can log block 002 and a few other ones for maf readings (stock car should have about 120 g/s, chipped about 170 g/s) if you get less than that or irregular readout then your maf could be going bad. Block 001 also gives you throttle angle/ignition timing. Block 002 - intake temp. Block 007 gives you lambda values (as voltage - narrow band o2 pre cat sensor in early cars) should be b/n 0.75-0.9v, if it's above 1 means you are running lean.
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
    Dec 2007
    Melburg East VIC
    hey Gavin, how did you log boost on you a3? i thought you had an agu engine like me, just a different ecu (yours ending with 018R), do these have a map sensor?
    Quote Originally Posted by schwartza3 View Post
    Mine was an AQ. I used an Innovate LM1 and Aux Box to log boost and lambda. You view the results with logworks.
    Happy to email you some if you download the app to open them.
    Adelaide hills, SA
    Vag-com Logview
    I found this program to be really good when I want to convert VCDS loged data from excel table to the graph.
    http://www.mediafire.com/file/eyityy...view_0_1_6.zip
    Aug 2009
    Melbourne, Vic
    Initiatially I thought why bother as VScope is included in Vag-Com. But after loading it up I see it does stuff the included VScope can't, so is worth having. Thanks for the tip Transporter.
    Dec 2006
    Kilsyth, VIC
    Rosstech is a bit of a black art from what I make out. I don't know how people work these things out. If there is a decent "how to" manual about for it I wouldn't mind reading it.
    Mind you with a Mk3 there isn't a lot you can do, still for $20 it's a bit of fun. Just gotta get it up and running on the new laptop.
    Aug 2009
    Melbourne, Vic
    Twincharger 1.4
    I have only read their official manual which you probably also have. Shows you how to run the software and basic stuff but I too want more info. Suspect a proper service manual for my car would be invaluable but cant see myself affording one. Sure is a learning curve.
    I have the 118TSI Twincharger and my engine controller is the 03C-906-027-G. Unfortunately it appears there are no Ross-Tech labels files for it yet. This means some of the eye candy does not appear like specifications for values. But still all works OK. Same with the DSG7 controller 0AM-300-046-C which is also missing label files. Chasing it up with Ross-Tech but nothing heard yet.
    In the mean time does anyone know if there are measuring blocks to show when the supercharger or turbo are cutting in and out? Boost press obviously indicates one or other or both are running. But I was after something specific to track each device. How about the divertor valve thingy position? I know thats not its real name but the valve that allows the air to bypass the supercharger. Be good to able to see what it is doing.
    Adelaide hills, SA
    Quote Originally Posted by logger View Post
    And did you noticed that you can jump from saved excel table when you select a row with data straight to the graph and row you selected is a cursor. I like it I think that it is much better than graph mode from Ross-Tech.
