DNA Tuning (Australia)
Results 1 to 4 of 4
Thread: Rings and bearings
    Feb 2006
    Camberwell, Victoria
    Rings and bearings
    Hey guys,
    I have taken out the rods and pistons to check the conrod bearings.
    They are not bad, but i'll change them anyways.
    THe question remains...
    Do i have to change piston rings if i take the piston out???
    Do i need to get new conrod end cap bolts???
    Do i need to touch the cylinder walls at all???
    Thankyou!
    brackie Guest
    Which engine?
    Quote Originally Posted by golf3
    Hey guys,
    Mic the big ends and check for wear. You may need a grind.
    No but you should anyway.
    Don't know which motor you're working on. New bolts if they're stretch!
    Hone them to get the cross-hatch back.
    Thankyou!
    Feb 2006
    It's a 2.0L 16v ABF
    sydney
    I agree with brakie
    new stretch bolts for the con rods & you should get some for the head too.
    new rings and bearings. you'll be up for a couple of hundred dollars but the bottom end should be brand spanker.
    It's alot easier to do it all now then later
Similar Threads
  1. Head gaskets and rings
    By hiho in forum Diesels
    Last Post: 05-05-2006, 07:04 AM
