I'd say have you had it reset/calibrated first. You have to make sure the DSG works properly before flashing or you just end up in a circle trying to fix hardware problems.
Depending on how deep Revo go with the tune, you can alter engage points from standstilll and reduce slippage to an extent by increasing clutch pressures. It still could be masking an underlying fault though.
