Results 11 to 20 of 34
Thread: Rev limiters on MK3 8V's
    Sep 2006
    West Sydney
    Yeah I can get mine to 6000+, ADY engine code which is what you should have too!
    Similar thread on Vortex - http://forums.vwvortex.com/zerothread?id=3619171
    The general consensus in there has been a defective coil - did you recently replace yours?
    Jan 2007
    Yeah I did change the coil recently, the limiter is still at 5 flat. I think the timing might me be out the belt was changed when I first got the car like... 30 months ago they did the job at Midas
    But I knew very little about VW's back then, and they did a decent job on the clutch and other parts so I can' bag them out to much. I've been complaining about the limiter and such for a while. And I remember Ray's car being faster than mine (maybe I just suck haha)
    And to think I was looking for a performance chip to move the limiter up hahaha oh dear, thanks guys
    Now I finally have an excuse to get that wobbly cam and ported head I was after
    Boronia VIC
    My MK 2 K-Jet 1800 revs clean off the tacho and into the fuel gague! (7K rpm +)
    My MK 3 1800 has seen the wrong side of 6200 rpm as well, but it's running a DGAV Weber so there's nothing to stop it except common sense.
    Pete
    Just alittle info,
    Some K-Basic sytem's still have a rev limiter incl. my 83 GTI. It's built into the rotor button in the distributor.
    Early BMW's have this system as well. It's a pretty nifty setup. Basically uses centrifugal force applied to a predetermined spring load which create's a dead short through the dizzy shaft.
    Boronia VIC
    Quote Originally Posted by golfworx View Post
    Just alittle info,
    I've seen those in type 4 Kombis too. (Usually disabled).
    Pete
    I'd have expect the rev limit to be 6.8 maybe even 7.2 or thereabouts.
    May 2006
    byron bay area
    [QUOTE=golfworx;176066]Just alittle info,
    I always thought it was good old fashioned valve bounce
    I can rev mine to around 6800 till it starts bouncing off limiter !!
    Only way to get some decent power out of the little 8V is rev the biatch
    Feb 2007
    Quote Originally Posted by Lorenz View Post
    I thought they dont like to be reved? My power cuts out after 5k even though the limiter is at a bit over 6k. Wheels will spin up on the wet after 3k in 2nd under about 60% throttle, so i guess thats where the torque comes in, no point goin much further then 5k.
    MK1 GLS 3door
    A4 B7 2.0T
    Im sure Robin will clarify, but my 2L likes to rev more so than others. Not sure why, but could be a combo of lightend fly wheel or cam/chip possibly! Dont no much about the history of the car though Either way I have to rev it to make power
