DNA Tuning (Australia)
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Rev limiters on MK3 8V's
    Jan 2007
    Hey everyone, just wondering what people have found to be the rev limiters on their MK3's. Mines at a flat 5,000 and at first I thought there wasn't a problem but until I started looking at a few other cars here and overseas, it doesn't seem that 5,000 isn't always the case. It seems to vary from 5,000 to 5,400 to even close to 7,000
    Is this a normal thing; or does VW have different versions of the same engine; or worse yet there is a problem with my car I've heard things about cars going into "limp mode" and not kicking past 5,000, although I hope that isn't the case. The car is a 1998 Golf 2E 2.0L by the way.
    Your thoughts and experiences will be appreciated
    Sep 2007
    hahah.. do 8vs even come with limp mode...? aren't they always in limp mode?
    sorry to crap up a reply i know that mine doesn't, but it's k-jet..
    87' MK2 GTI
    13' MK7 TDI
    Jan 2007
    Quote Originally Posted by jayjay View Post
    thankyou for your valulable contribution to our online community
    Your k-jet doesn't have a rev limiter?
    Sep 2007
    hahahaha
    i dont think so... it doesn't have an ecu.
    are you maybe just leaning out like crazy?
    i dont actually have a clue sorry, i'm just really sick of studying
    87' MK2 GTI
    13' MK7 TDI
    Boronia VIC
    Some models have a rev limiter built into the fuel pump relay. They can be changed for non-limiting type. Usually the RPM limit is printed on the side of the relay.
    Pete
    Jun 2006
    my 8v used to cut out at aroud 5
    but then i installed a lumpy cam, it took it all the way to 6500 safely without a bounc before i back off...then my head gasket exploded power was there as well, through the whole rev
    Camden, Sydney
    5000 is too low. Timing is probably out. It should be 5800 with the later 2Ls 6200 with the early ones.
    May 2006
    byron bay area
    My mk2 goes easy to 6000rpm on digi
    sounds like that relay switch is worth a look
    yeah 5k is 2 low you got a problem some where, could be the timing if someone has been playing with it or you've had the t belt changed and not set right. also could be fueling . get it checked out.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Feb 2007
    Ive never hit the limiter in mine, 94 (2E i think). I am sure that it has been close to 5700 though, only once....there is not real point anyway
    Mk3.Mk4.Mk1
    My Mk1 Project
