Results 1 to 4 of 4
Thread: R36 - Worth Getting a Tune
    Mar 2015
    Launceston, Tasmania
    Hey team,
    I'm sure this has been discussed before, but is a tune for an R36 remotely worth it?
    I'm thinking the DSG tune itself and leave the ECU alone as it's pretty highly strung from the factory however increasing the revs a touch to act a bit more like a normal auto would be nice.
    Also - would a Haldex controller be worth it over a tune?
    ECU tune is 5-10kW at best. You’re right there’s probably more gains out of the DSG in terms of drive ability and torque limits.
    I had a gen4 Haldex controller in my gen1 Tiguan and it certainly improved the front wheel bias shifting more power to the rears sooner and making more a 50/50 split. It’s a good mod but is still reasonably pricey for a relatively small gain in n some driving situations. It certainly makes it more enjoyable in the twisties but as you say there’s not a whole lot of gains to be had on an R36 without tipping a heap of $ in.
    I’d probably invest in a decent set of tyres first.
    Jan 2020
    Doing the IE ecu tune just now has shown me how outa whack the DSG tune is, going to go for a box tune over a controller (I think, more research required)....
    Have a look here for R36 tune info (although this tuner is no longer active in Aust as far as i am aware it will give you an idea of what to expect) .
    +15kw peak and +25nm peak but nothing really noticeably below 4,000rpm. But above 4,000rpm it would certainly be noticeable. And throttle response is improved making the engine feel more eager.
    DNA Tuning Introductory Special for Passat R36
