Results 1 to 10 of 16
Thread: Post ECU upgrade boost leak???
    Nov 2012
    Hey guys,
    I got the GIAC stage 1 tune done to my Scirocco R and lately Ive been noticing a slight stutter/boost leak on acceleration under boost.... Some friends tell me it sound like a compression surge.... any thoughts or anyone noticing a similar problem?
    When you put your foot down and hit about 3,500rpm + you can hear a stutter in the boost.... hard to explain... at first I thought it was an exhaust leak but now my mates have told me different so Im not sure...
    Is it caused due to the tune? Is it normal? Can anything be done to resolve the problem??
    Cheers guys
    Quote Originally Posted by sduktv View Post
    Hey guys,
    Cheers guys
    You should be talking to your GIAC supplier, I would expect them to datalog it.
    It wouldn't be unusual to have a boost leak but logging is the quickest way to see.
    A quick check of the PCV system involves, undoing the oil filler cap. If you can lift it off easily, the PCV is probably ok. If it is a bit harder to remove and runs badly with it off, the PCV system needs looking at.
    Nov 2012
    Thanks Gavin I shall do that!
    Appreciate the help.... Its only got 6000km on the clock... Scared the hell out of me!!! It would be a real shame for things to start giving out already... Thanks for the advice!
    Honestly the PCV system is pretty weak. A customer of mine had one replaced at Audi 2 months ago and it's gone already. Just plain rubbish. I'd get a delete plate/block off.
    Point Cook, Vic
    If it was compressor surge you would have driveability problems.
    The sound if its what im thinking is pretty normal and nothing to worry about. The stock tune does it sometimes too if you listen closely. Nowhere near as apparent though.
    FOLLOW US ON FACEBOOK
    Aug 2008
    Worth checking your diverter valve as well, although they are the upgraded piston type they are not 100% once boost levels increase post standard.
    Sep 2012
    Not sure if its the same thing, I'd also like to get some views on something that happens with my car - it has only been noticed since the TBE was fitted. Occasionally, when I plant the foot hard in 2nd or 3rd, instead of getting power down I get a lot of exhaust spluttering noise and the power doesnt come on properly,. It all happens very fast and I basically let off the accelerator and then re-accelerate and its ok. The sound is loud - from the exahust, sounds like a massive, spluttering expulsion of air.
    I've emailed the mechanic over the holiday break and will take the car in next Monday when they re-open...unless it seems normal. The worst thing is it generally happens at times when I am expecting the maximum performance - like competing against another car or lane changes with a fine margin for error.
    Hey guys,
    Cheers guys
    Not an uncommon occurrence, but more likely in colder weather. There are a number of potential causes; none of any major concern. Is there a noticeable reduction in engine output when you're hearing the sound?
    Quote Originally Posted by shimee View Post
    This is merely the ESP system cutting in. The exhaust flutter is more noticeable, though, because you're now using a louder system. Try switching off the ESP and the sound should go away, meaning you'll wheelspin/axle tramp with flaring revs instead. It's still apparent on a standard car, but far quieter.
    Apr 2006
    VW Race HQ - Sydney
    Thats not how the PCV works on TFSI engines , its the other way around ..
    Bug_racer supports the rebellion of the euro revolution
    Point Cook, Vic
    The issue isnt a boost leak or faulty PCV anyways.
    As mentioned if the driveability of the car is fine then I wouldnt stress. The noise is normal on most tuned Rs ive been in (including other vendors) and also possible to replicate on a stock R if you hit the throttle at low RPM in a high gear
