Not really a case of the tune being bad. More a case of the tune is stopping me from comparing it with another tunes and the only people who can easily solve this issue for me are not helping.
MkV Jetta
2.0T FSI
I have received a reply from APR USA to confirm that post the 6hr trial, the information on the ECU is a 'stock calibration' not 100% VW Stock.
Here's the quote from the email:
'After 6 hours the ECU goes back to stock calibration however there is still APR software present in the ECU. To remove the APR software you will need to take the vehicle back to the APR dealer so they can flash the car back to stock.
Thanks
Chris Teague Â
Technical Support Rep.
APR, LLC.          Â
4800 US Hwy. 280 W. Â
Opelika, AL 36801Â Â Â
Phone: (800)680-7921
Tech:Â (334)502-5181
Fax: (334)502-5180'
So i guess that is my solution.
MkV Jetta
2.0T FSI
Sounds like the various APR dealers here in Aus have been telling fibs then about their "stock" software.
It could be worse.
I've heard of a case (different company and country) where the wrong trial map was loaded and the car was detuned afterwards to a lower spec model.
I'll see if I can dig out a link.
Even if you use BDM to remove the 'trial' maps and then replace this with the original stock file back in the proper mapping areas the car will not start. You have to get APR to remove their tune AND return the other areas of the ECU back to stock
Revo,uni and some others do the same too I'm not sure if GIAC do though. If someone has tried to use a bluefin on a Giac tuned car and it works then it's all good if it doesn't then add them to the list as well.
They can restore your ECU back to stock. I've had cars go back and then afterwards we can happily communicate with the ECU once more. Happy days !!!![]()
