Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Post APR 6hr trial complications
    Aug 2007
    Hi everyone,
    Couple of weeks ago, I had an APR dealer in melbourne give me a 6hr trial of Stage 1 APR. It was the first experience I've had with a chip tune and wanted to compare what other tunes were capable of.
    Contacted another tuner in Melbourne who was kind enough to come round and answer all my question and was willing to give me a trial of another tune. Only problem is when he plugged in the device which reminded of a 'bluefin' device. It spat out all sorts of error codes.
    I told him that I had an APR trial run beforehand but it's 'all back to stock now'. He told me that the car might be performing at a stock level but APR's code is still in my ECU and that I needed the APR dealer to revert it back to 'full stock' in order for the new tune to work properly.
    I've since called back to the APR dealer in question and have called APR Australia's help line and both have assured me that 'stock is stock' and that APR's code 'disappears after 6hrs' and 'if it can be overwritten by your dealer, any other tuner can overwrite it e.g. Giac, Oettinger' (inverted commas are their words, not mine)
    This whole things has left me very confused and somewhat frustrated. I'm being told conflicting information by different people.
    Can anyone out there help to clarify the situation for me?
    Thanks everyone!
    p.s. I've done some searching and it seems other people may have had a similar experiece as me.
    e.g.
    APR Trial - Can't reinstall bluefin [Archive] - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com
    MkV Jetta
    2.0T FSI
    Oct 2006
    I'd comment, but id get in trouble.
    ive heard several people in sydney alone with the same problems.
    It is "aprs" stock code.. it is not VW's stock code.
    Aug 2007
    And also, I know how sometimes posts about ecu tuning can get people worked up.
    Don't want to get anyone in trouble.
    I want to side step any of that controversy and just ask the simple question of:
    Does 'post APR 6hr trial' Stock = '100% VW' Stock?
    If yes then case closed.
    If no, then how do I get my original 100% VW stock tune back?
    Thanks
    MkV Jetta
    2.0T FSI
    Point Cook, Vic
    Quote Originally Posted by turboveedubb View Post
    Thanks
    APR stock = standard calibration but not 100% stock ECU otherwise your bluefin would work.
    Aug 2007
    Ok, quite a few people are of that opinion. So how do I get my 100% stock tune back?
    Thanks!
    MkV Jetta
    2.0T FSI
    This is my take on things.
    The APR trial has to be a replacement code in my mind. You have no ability after the trial finishes, to switch between programs, that I am aware of.
    They are partially correct that there's no problem flashing over the trial. I have done a few personally. The problem I think you are having, is that you need to read the standard code and send it to Superchips. Superchips alter that and send it back to you. As it's not the standard code in the ECU then there's a conflict occurring.
    I am sure Guy will be along shortly to clarify what's happening.
    Aug 2007
    Hi Gavin,
    That does make sense. The 2nd method of tuning I wanted to try does involve copying the ECU information.
    Emailing the file off for it to be altered off-site then sent back and put onto my ECU.
    What I'm frustrated about is the reluctance of the APR dealership to put my car's ECU back to the way it was originally presented to them. I've asked them twice about this, first time over the phone, second time in person and they assure me that 'stock means stock'.
    MkV Jetta
    2.0T FSI
    Nov 2010
    Kensington, Victoria
    turboveedub,
    your experience actually changes a lot of things for me. i'm going to be receiving my car soon and will be looking to try at least 2 difference ECU tunes to decide which I should go for. APR would definitely be one of them since the majority has got them done, however if APR dealers are uncooperative and the ability to go back to pure 100% VW then I'm not convinced to go ahead with them.
    would you mind privately messaging me which dealer is this in question?
    [Current] Audi A4 B8 MY2013 2.0T Quattro - Lava Grey, Black Edition, S-Line, 19" TT-RS Wheels
    [SOLD] Golf GTI MK6 MY2011.5 - Candy White, 5-Door, Manual, Sunroof, Park Assist, 9W7 Bluetooth RVC, MDI, Dynaudio, RossTech MicroCAN, Bluefin Stage 2, LED Tails, VW Racing Panel Air Filter, 3" Eurojet Downpipe, Milltek non-Resonated Catback
    Jan 2009
    brisbane queensland
    Hi i had this problem with my mk5 gti after the trial tune from apr. I would suggest that you go back to VW and get them to do a softwear update that way it should over right the tune and load a proper stock VW tune onto your car
    YAY I got my R!!!! White, recaro seats, 19" wheels, bluetooth, reverse camera
    Apr 2009
    GIAC Software overwrites the ecu and also repairs and fixes the EEPROM and puts it back to original VW coding.
    For your closest GIAC dealer visit: GIAC Dealers or alternatively, see your dealer. I would be cautious of going to your Authorised VW dealer as some in the past will make a note of this on your file and it will stay on your permanent record. In future if you may have a large warranty claim they could use this against you.
    Genuine VW Parts Importer | Navigation | Bluetooth |
    Repairs | Lighting | Coding | Programming |Cameras
