DNA Tuning (Australia)
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Polo GTi with APR Tune - Check Engine Light?
    Jun 2008
    Ringwood, Victoria
    Thanks for responding to this so early Guy.
    I see now that there is also replacement coil packs on the market for these motors.
    In your opinion, due to the regular issues seen in vehicles with spark related misfires in tuned and stock vehicles, would you recommend replacing the factory plugs regardless? I know that Revo in Europe will not tune one of this cars without also replacing the spark plugs.
    Apr 2010
    Will that DSG update be for all 1.4 Twincharged cars? (i.e. my 2009 Golf). Looking forward to it.
    No problem Gav's, there has been dozens of minor calibration changes on the twincharge motor over the time, on the MK5 GT there were 18 different versions .
    Not sure on the coilpacks, VW have been plagued by coilpack issues since 1998 (you would hope they would have sorted it by now), but it wouldn't surprise me if that is a contributing factor at all.
    Ryan, yes, our DSG software will be done for the Golf's as well. We just finished testing our new "D" program on the 7 speed, holds 1st gear over 15kmph (save up to 3 un-needed gear changes on light throttle) for traffic driving, and a new "softened" S mode as well. Very excited about it (as well as the torque limit control), so looking forward to a couple more Brisbane test cars before release.
    Nov 2009
    SEQLD
    Guy, do you know the part number for the new NGK plugs??
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
    The new Audi specific one (for the high output A1) is PZFR6R8EG, have not been able to purchase those in Australia as of yet.
    We have been using the BKR7EIX gapped to .8mm with good success.
    It's a bit hit & miss from VW & Audi, their parts numbering system doesn't mean you will get current plugs, sometimes old stock, so double check all part numbers.
    Nov 2009
    SEQLD
    Ok thanks. Yeah I bought new plugs from VW spares hoping they were the new part number but they are the same as what came with the car from factory. Still put them in. I don't seem to have the misfire problem.
    MY20 Golf GTI TCR
    Apr 2010
    Sounds fantastic. When in D half the problem is the time the car takes to think about which gear it should shift down to before getting all that APR goodness, sometimes I'm too lazy to put my left hand on the wheel to downshift myself (esp on stop/start freeway trips)
    I trust you'll let us know when to give Dean a call.
    Jun 2008
    Ringwood, Victoria
    Yeah, with another major revision in September.
    Yes, mk4 golf saw the first of the coil pack brilliance I believe...
    Jan 2012
    Canning Vale, WA
    2: Overboost : exceeding the requested boost limit on a boost overshoot. Can cause limp mode - loss of power & may require a key off / key on cycle to get back to normal. Colder weather (cold air = more density = more boost) has bought this on in cars that have never seen it. Part of it is because of the DSG shift command (where the transmission goes to shift & reduces engine load) and there is a boost overshoot. We experienced this a few weeks ago on our own big turbo Polo in Goulburn at 4 degrees C where we have never seen it in QLD - we short shifted at the sprint event & didn't have the problem.
    It appears this may be the probable cause here, although we haven't seen temperatures close to 4 degrees, but it has been low to mid teens during most of my drives. But in anycase, HP have been very helpful and accommodating as has Quattro motors over here. They are planning to apply the upgrade this week so all being well it will resolve the issue. I am thoroughly enjoying the tune, the smoother gear changes and more power available, so I'd hate to have it all come crumbling down.
    Many thanks to James from HP for his help, it certainly is interesting to hear other stories of similar events!
    White 2012 Polo GTI - 5dr + Xenons, Alcantara & Sunroof
    Mods - Remsa Brake Pads, 17" Detroits & APR Stage 1 Tune
