Results 1 to 10 of 19
Thread: Polo GTi with APR Tune - Check Engine Light?
    Jan 2012
    Canning Vale, WA
    Putting a call out to the GTi folk with the APR Tune, have you had any issues with high end revs bringing up the check engine light?
    My car has about 3000kms on the clock and have had the APR tune for about 1500kms of that, in the last 500kms a strange thing has been happening that has me worried.
    I have had the engine check light come on 4 separate occasions. On the first three occasions the engine check light flashed after the car reached 7000 rpm in either 3rd or 4th gear, at which point I immediately reduced throttle. But on the 4th test yesterday, the same situation occurred, with the flashing engine check light, however after 20 seconds of flashing the light remained on. And it is still on today.
    I'm really unsure of whether it is my car or my driving, the car isn't going into limp mode, but there is a noticeable flattening of power.
    I've booked it in with Quattro motors again, but wanted to know if anybody else had seen the same?
    White 2012 Polo GTI - 5dr + Xenons, Alcantara & Sunroof
    Mods - Remsa Brake Pads, 17" Detroits & APR Stage 1 Tune
    Melbourne, Victoria
    Stupid question but out of curiosity what are the levels on the dip stick saying?
    2011 Polo GTi
    Apr 2010
    You might want to grab a VCDS cable or other OBD2 adapter and see what fault codes are being logged before a dealer has a chance to look at it.
    Oct 2011
    Atwell, WA
    if you get a chance ask for a refund... APR seem to have too many problems tuning this engine...
    refer to my video - (2012) Polo GTI 6R APR Tune Issue - YouTube
    changed spark plugs and now have another tune from APR with less power, but still have power distribution issues...
    grab your money and run...
    2012 Volkswagen Polo GTI (Shadow Blue) | Current Upgrades - APR Stage 2 Tune | GFB DV+ | HP Cold Air Intake | OKADA Plasma Direct Coil Packs | HP Exhaust | HP DQ200 Tune | Whiteline Rear Sway Bar | Uprated Engine Mounts Planned Upgrades - | Coil Overs | HP Intercooler |
    Apr 2010
    Strange one, were APR able to diagnose the issue? I've never had faults with my APR Twincharged Golf
    Apr 2012
    Wow this has really made me second think my thoughts on getting a tune. I spoke to one of the guys at exoticars and ram speed they both sound positive towards tunes. I know they just want money but I can't imagine how a little 1.4L can be put under so much stress....!!
    Get your $$$ back!
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
    Sep 2010
    Melbourne, Victoria
    Did you have any problems at all stock?
    Quote Originally Posted by RandomX View Post
    Oct 2011
    Atwell, WA
    Quote Originally Posted by DNA Tuning View Post
    none...
    just no fun
    Jun 2008
    Ringwood, Victoria
    Have a look here too....
    Seems to be an issue not just here.....
    There are two issues with the twincharge motor:
    1: Spark related misfire, well documented & occurs on twincharge motors in stock form & tuned form. VW / Audi have revised spark plugs & specific gaps, so if you see a misfire issue, first call is new plugs and specified gaps (thats also VW's first fault fix procedure) - Harm to engine? zero. Also happens with higher mileage FSI engines & carbon build up internally in cylinders (not just twincharge motors).
    2: Overboost : exceeding the requested boost limit on a boost overshoot. Can cause limp mode - loss of power & may require a key off / key on cycle to get back to normal. Colder weather (cold air = more density = more boost) has bought this on in cars that have never seen it. Part of it is because of the DSG shift command (where the transmission goes to shift & reduces engine load) and there is a boost overshoot. We experienced this a few weeks ago on our own big turbo Polo in Goulburn at 4 degrees C where we have never seen it in QLD - we short shifted at the sprint event & didn't have the problem.
    Fix: If your car is diagnosed with either, there is a software update that addresses the overboost code, and the updated NGK plugs available if you have a misfire issue.
    We are working on testing the new DSG software that has modified the torque / shift part of the map in the way it pulls the load back, Faster, safe shifts with more power. Not ready for the release of that part of the program yet (testing still underway).
