Results 1 to 6 of 6
Thread: polo 9n3 downpipe query
    Jan 2012
    Bentleigh East, Melbourne, Vic
    hi all,
    i am doing some research on downpipes for the polo 9n3 gti.
    firstly, i am looking for some information on the differances between a 2.5" and a 3" downpipe.
    secondly, i though i would ask if anyone could give me a few comments on what they are running, and their views. i am a huge fan of apr, but before looking at the downpipe, i would like to do some investigations....
    appreciate your asisstance all
    thanks
    Clint
    Eltham, Victoria
    Hi Clint,
    I'm running the APR downpipe which is 2.5" through to the highflow cat.
    I've found it's allowed the turbo to spool up quicker and sounds better under load.
    At idle you wouldn't even know it's there.
    Whichever route you go down, you'll have to invest in an o2 spacer to eliminate the likely Check Engine Light that will appear due to the increased airflow.
    If you want I can happily show you my car of you're interested.
    Cheers,
    Ryan
    Oct 2009
    Canberra ACT
    Hi mate, running the same as Bflat. No problems whatsoever and it works as described in the above post
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
    Jan 2012
    Thanks BFlat, I may indeed take youp on your offer .
    I am just debating onthe 2.5" vs 3" diamater , and what difference this will make to sound / performance.
    Feb 2008
    ACT
    Quote Originally Posted by clicht View Post
    I originally installed the APR 2.5" down pipe, which included the appropriate adjustments to my APR tune to prevent (or ignore) the CEL issues. The exhaust note did change slightly but it was still quite subtle.
    I'm now running a 3" custom exhaust from turbo back, and that's a whole different story. The burble on overrun is fantastic, and the rumble at idle is very enjoyable, but it's absolutely horrid at highway speeds with a drone that will drown out everything and give you a headache after a few kms.
    I don't think things would be so bad running just a larger down pipe without changing the rest of the exhaust system, but if I was looking for a compromise between performance and retaining drivability I'd go with the 2.5" down pipe.
    Aug 2007
    Perth WA
    '04 BMP MkIV R32 #144
    search getnew
