Results 1 to 10 of 16
Thread: Pod filters and K-jet
    Jul 2005
    Melbourne, Williamstown
    Hey people, Has anyone fitted a pod filter to their Kjet car? I'm thinking of making up a lower airbox section out of sheet aluminium and having it funel down into the shape of a pipe allowing me to fit a pod filter.
    Has it been done?
    How succesfully?
    Suggestions?
    Cheers Carl.
    mk2 GTi 16v
    Corrado G60
    Jul 2005
    Here's a very basic idea of what I'd like to do, ofcourse I'd make a bit more room for the metering arm to move within thew box and maybe have a shroud around the pod itself, well the engine bay side.
    Suggestions?
    mk2 GTi 16v
    Corrado G60
    You can actually buy the base/kit new from memory.
    It come's with a cast aluminium base & filter
    I'll try & dig up some pics
    Jul 2005
    would be good if you could. My mate just put a pod filter on his mx5, which sound like poo as standard, sounds so much better it's not funny. I can only imagine how good mine would sound with a pod and a power rhor (SS induction pipe).
    mk2 GTi 16v
    Corrado G60
    I thought I'd seen them before as there were fitted as standard to Volvo 240T & a standard bosch part.
    There sometimes on ebay too from these seller's
    greggearhead Ebay I.D.
    http://myworld.ebay.com/ebaymotors/adidascu/
    This would also suit Mk2.
    Jul 2006
    Sunshine Coast....Moved up in jan 06 from Tas
    id say u will prob get more perfomace out of a drilled box with a k&n filter...an mx5 loves the pod they gain like 10-15 hp just for a filter.. th pod would look pretty cool though
    I done that with mine & it look's like swiss cheese!
    The only probably is that you tend to get to much hot air from the engine compartment. The pod filter is a good idea, but on a Mk1 you still get the warm air off the radiator!
    Before I drilled the crap out of my airbox, I tried a duct from in front of the radiator which worked O.K. but the down side is you still need a large duct to make it work & you can only fit so much in front of the radiator & around the battery. If you relocated the battery & made a duct from the headlight into the airbox, I reckon you'd see the difference.
    A Mk2 will be diiferent as they can grab air from behind the headlight & spotlight area, not the radiator.
    Aug 2005
    Stroeve Motorsport have been making one for ages - you could quite easily copy the design with some alloy and a welder The filter connects to a pipe which is welded to a hole through the plate.
    Jul 2005
    Thats right I had been trying to remember who made them. That one looks nice.
    mk2 GTi 16v
    Corrado G60
    Jul 2006
    ive got a mk2 k-jet set up and my fuel dizzy is on the right side of the car (drivers) and it gets cold air ok in that spot.. its a really tight fit, i have to take the airbox out to disconect my headlight. all k- jet setups ive seen have the dizzy on the left side, can any1 tell me why mine is the other way around, is it cause its a mk2 engine. just like to know..
Similar Threads
  1. K&N Filters
    By static1800 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 04-03-2007, 09:53 AM
  2. Diesel Particulate Filters...
    By mk5mayhem in forum Mk5 Golf & Jetta
    Last Post: 10-10-2006, 07:49 PM
  3. Biodiesel
    By flightlessbird in forum Diesels
    Last Post: 04-09-2006, 07:23 PM
  4. Engine Oil!
    By vee_dub in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 10-05-2006, 05:02 PM
