DNA Tuning (Australia)
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Pod filters and K-jet
    All Mk2's 8V's & 16V's had the fuel system/airbox assembly & what not fitted on the RHS. Mk1's had it on the LHS incl. the Scirocco's
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by silverMK1
    id say u will prob get more perfomace out of a drilled box with a k&n filter...an mx5 loves the pod they gain like 10-15 hp just for a filter.. th pod would look pretty cool though
    Do you have dyno figures ?
    We lost a second a lap with the race car around wakefield using a pod filter vs stock airbox .
    midget Guest
    is this issue anything like my recent post?
    http://www.vwwatercooled.org.au/newf...ead.php?t=2229
    Jul 2005
    Melbourne, Williamstown
    Quote Originally Posted by midget
    nothing like it, since the K-jet system is a totally different FI system with a non circular hole to fit a pod filter to.
    And as for performance gains/losses, I'm really not too fussed, if I had the same performance and it sounded better I'd be happy. That said naturally I would like to avoid a performance loss.
    mk2 GTi 16v
    Corrado G60
    Lightbulb filters
    I have the k-jet setup running my 16v, no swiss cheese on my box i've cut the bottom out of the box altogether leaveing a few bits on there to secure it down and running a K&N panel liter and i pretty pos that i've gain a little in the performance and a lot in the induction dep but it's just the right note.
    Having said that i believe that you would if anythink gain more from a panel filter with the bottom cut out vs a pod as the would be absolutley no restrictions and at the same time you leaving the look std, you can vent some cold air up to the bottom of the filter via two flexible pipes from somewhere in behind your bumper.
    Well that's what i've done it was simple looks neat and tucked away and the induction works great i've tested it with me trusty old leaf blower from about 2m away from the front of the car and heaps of fresh air being vented up to the filter.
    just an idea,
    'm sure others would have done the same as i have many years earlier.
    Just to add a little bit more those cast alloy inuction boxes would be great for a turbo k-jet setup.
    Cheers Dave
    _________________________
    mk1 16v wet clutch now in the bin,in with the button clutch today, exhaust repairs tomorrow,
    Jul 2006
    Sunshine Coast....Moved up in jan 06 from Tas
    Quote Originally Posted by Bug_racer
    i personally dont but i was reading a hot4s mag and they did just that and dynoed it, it was much better, this was a n/a version i think 90kw standard
Similar Threads
  1. K&N Filters
    By static1800 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 04-03-2007, 09:53 AM
  2. Diesel Particulate Filters...
    By mk5mayhem in forum Mk5 Golf & Jetta
    Last Post: 10-10-2006, 07:49 PM
  3. Biodiesel
    By flightlessbird in forum Diesels
    Last Post: 04-09-2006, 07:23 PM
  4. Engine Oil!
    By vee_dub in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 10-05-2006, 05:02 PM
