DNA Tuning (Australia)
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Performance upgrades for the 118TSi engine without effecting warranty
    From my VW contacts , the only engines they have seen/are still seeing failing are all stock. All the tuned ones are much happier and the reason being is that this is what happens when you stop running the AFRs so terribly lean as occurs with the earlier stock files.
    Dec 2013
    jimboomba QLD
    Hmm Thanks Guys, I might leave the engine alone for quite a while, I also invested in a 3yr extended warranty so 6 years total so fingers crossed no troubles.
    Erskineville, NSW
    Read the fine print on th eextended warranty - that will tell you what you can & can't do (pretty much nothing).
    Feb 2008
    ACT
    Quote Originally Posted by ohhbugger View Post
    Might have been a forced decision anyway, as I'm not sure anyone has a tune for the latest generation 1.4s as in the new Beetle. Certainly APR haven't cracked it yet as I'm still waiting for the tune for my Beetle, and I haven't heard if any of the other big players have cracked it yet.
    Adelaide hills, SA
    Quote Originally Posted by jamesatfish View Post
    What year is yours? My son in law has 2011 Golf6 118TSI and there is an Autologic performance tune for it. It could be worthwhile to you to find the independent VW mechanic in your area who has the Autologic diagnostics, I find their tunes as very good. They're only stage1 though, but very refined.
    AUTOLOGIC over OBD2 port Performance Tunes at MRL Automotive
    Feb 2008
    ACT
    Mine's a June 2013 build - apparently the newer ECU has much stronger encryption than the previous versions so hasn't been cracked yet. I believe the latest Polo GTI suffers the same issue.
    I will check Automotive though incase they've figured it out- thanks!
    Yep, APR are still working on the new ECU's for the second generation twinchargers (MY 12.5 >) 2008 > 2012 are very easy to program.
    Dec 2013
    jimboomba QLD
    I got an email back from the ABT outlet in nsw. They are doing a piggyback plugin ecu for the 2013 *Beetle 1.4 TSI 118 kW (160 HP), 240 Nm to ABT 154 kW (210 HP), 290 Nm*-*$ 2,590.00 incl. GST
    Not sure if its any good or not. Also can the oem still detect if there has been a pighyback computer installed ? Will the factory computer sense its there and log the warranty denied code ?
    Dec 2013
    jimboomba QLD
    Im really liking ABT's 20 inch wheels but they are bloody expensive !! $6500 for rims and tires
    Jun 2009
    Anything ABT is expensive, it is a premium upgrade service
