Results 1 to 10 of 21
Thread: Advice - How to remove crank nut?
Peter Jones Advice - How to remove crank... 16-03-2008, 09:18 AM
h100vw Why do you need to remove it?... 16-03-2008, 09:34 AM
Peter Jones Need to replace the oil seal... 16-03-2008, 10:04 AM
Peter Jones Got it! Lots of leverage,... 16-03-2008, 10:19 AM
h100vw Good effort mate. Remember... 16-03-2008, 10:30 AM
    Oakleigh VIC
    This sucker is done up real tight.
    I've thrown a heap of leverage at it but it's not budging.
    I'm locking the crank with a 1.5m bar bolted to the timing belt pulley. I keep tearing the bolt holes out of this bar.
    I'm also close to bending my breaker bar.
    I'm going to see if I can find a bit of plate and attach to all 4 bolts.
    Might try to heat it up a bit too.
    Pete
    Heat might work but they are in there funking tight. I have never removed one myself in nearly 20 years of VW ownership. Only when they have undone themselves on G60s and 16Vs.
    Certainly when you replace it, I can recommend that you use the hex bolt and washer from a MK1 DX engine. The stretch bolts just don't seem to cut it as replacements.
    Oakleigh VIC
    Need to replace the oil seal behind it, it's leaking.
    Just made up a new lever, hopefully this one will hold.
    Pete
    Oakleigh VIC
    Got it!
    Lots of leverage, swearing and heat and it finally let go.
    Now I bet the pulley will be stuck too!
    Pete
    Good effort mate. Remember the hex bolt can be reused the 12 points cannot.
    Oakleigh VIC
    Yep, it's the hex bolt, so all is well.
    The pulley came off easily,.
    I'll pop up some photos later.
    Pete
