Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
Thread: nitrous injection?
  1. #21
    syncro Guest
    Quote Originally Posted by Valver.
    LOL. Nitrous doesn't explode
    How on earth does it create havoc in the cylinders, upping the cylinder pressure hugely to make more power then :!:
    No it doesn't really explode, but causes anything else flammable to explode and there is the danger.
  2. #22
    Aug 2005
    Quote Originally Posted by syncro
    So explode isn't the right word, but you know what I mean
    If it didn't have any explosive properties, you might aswell pour 30wt suspension fluid into your intake.
  3. #23
    syncro Guest
    Hard to explain, but it increases the explosive properties of the fuel.
  4. #24
    Aug 2005
    I know how it works; the point is that it aids combustion to make power and thus has some explosive properties.
    It's certainly not "unflammable" as mentioned earlier
  5. #25
    Perth. WA
    read the article guy's , its all in there...
    nitrous oxide is an oxidizer, so it liberates oxygen which is when added to the intake mixture with additional fuel increases the efficiency of the combustion process in the engine relative to the original combustion cycle...hence more output...
    the stuff has been around since WW II from what i have read, so it's definately not as Hi tech as some make out... :roll:
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  6. #26
    nothin like big corperate names and good advertising to make simple laughin gas that grogs u up at the doctors seem new and fantastic
  7. #27
    Nov 2005
    the reason the nirtous exploded in fast and the fur... was because their was a fire before, therefore what happends when a compressed bottle gets hot? it expands whats inside and the bottle explodes not the nitrous! now when the bottle explodes the nitrous gets out and then it aids the fire creating a fireball!! am i right or am i right?
    wabit
  8. #28
    Apr 2006
    VW Race HQ - Sydney
    This thread is Gold
    Some people need to do a bit more research before posting
  9. #29
    yeah wabit thats right ,
    cheers brenton
  10. #30
    Ok guys it's not what's in the bottle that causes the prob in this case if it were to happen, it's the pressure that it is stored at that creates the risk of explosion. think about it 900-1000 psi in that bottle you wouldn't want to drop it on the concrete.
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. Replies: 1
    Last Post: 03-11-2006, 02:45 PM
  3. 1.8L CIS K-Jetronic injection problems
    By Anonymous in forum Mk1 Golf
    Last Post: 01-08-2005, 09:54 PM
  4. Toledo diesel??
    By imported_brackie in forum The Lounge SEAT
    Last Post: 07-07-2005, 11:18 PM
