I have just found out that Nitrous injection is illegal in Queensland.
told yas! thanks DVR68U AND DOHCDAVE
WABIT
its illegal in all states, you can have it but it cant be hooked up to any tubes, and has to be properly sealed
wabit
No, Queensland you can't have it.Originally Posted by WABIT
like i said, its IL-LEGALOriginally Posted by WABIT
No, in Queensland you can't have it at all. Even disconnected is illegal.
You cant have the bottle in there you mean
The brochure says Nitrous injection is illegal. I understand that as any components are illegal.Originally Posted by Bug_racer
It's ok to have installed. Depending on which state, you might not be allowed the bottle in the car, or even connected, or worse case scenario, the solenoids must not be routed to the fogger and the fogger must have disarming jets.
Jules
PS: First post on this forum. Hi guys hehe
Nitrouse oxide is a form of forced induction i beleive because it forces more oxygen (and nitrogen) into the combustion chamber. nitrouse oxide isnt explosive! It's the huge amount of oxygen induced by the engine and increase amount of fuel which gives the car the extra horespower, all the nitrogen does is stop the engine from melting. They tested this on old war planes they used pure oxygen in a bottle (to start with) so they could power out of dog fights ect. But aparently they had problems with the engines getting way to hot and melting, so they added nitrogen to keep engine temperatures down. (I could be wrong if somebody got more info)Originally Posted by Valver.
1977 VW golf 3 door
Toyota 4AGE Khanacross car
Gilera Runner 180cc
