Results 1 to 10 of 10
Thread: Oil in pipe going into intercooler !!
    Dec 2007
    Hi,
    I have a 98 passat 1.8t, just pulled the rubber pipe going into the bottom of the intercooler and around 3 tablespoons or oil ran out. I'm thinking this isn't good. What could cause this ? bad seal in the turbo ?
    Car doesn't really go as it should, I'm in the process of cleaning the MAF and throttle body, and then checking n121 sensor. Don't have a VAG Com but thinking I may need to find someone else who does.
    Dean
    A little bit of oil is normal. When the air is compresses it seperates the oil that's in it and is often found lining the pipes. I don't know about 3 table spoons worth however...
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    That could have accumulated over 10 years. I wouldn't worry. If the turbo seals have gone, there will be plenty more evidence behind you!!
    Dec 2007
    Thanks for the replies.
    Dean
    Jun 2006
    Orange NSW
    Take your turbo inlet pipe off and have a look and feel how shaft play the turbo has up and down, side to side and in and out. If it has more than 1mm its on its way out, but as h100vw said the evidence behind you in the rear view mirror will let you no for sure. A well screwed turbo will spew blue smoke under hard excelleration!
    Mar 2008
    Artarmon
    Dean,
    Pop in, I'll check it for you on Vag-com if you like, no charge. We are in Artarmon. Send me a pm and I'll give you our details
    Dec 2007
    mtm tcca
    I'm in Brisbane, but thank you very much for the offer.
    Dean
    Mar 2008
    Artarmon
    Dino,
    You are welcome, and sorry to hear we could not help. Might work for other members if they have a problem
    Jan 2008
    Have you considered installing an oil catch can?
    I have seen more than 3 table spoons worth collected in a catch can. Have you ever seen a catch can that is vented to the atmo? They quite often steam from the small breather filter after a hard run.
    Its worth considering and its on my to do list, before I get a new FMIC.
    How much oil is in the pipe there is always a little bit that will drip out after you remove it this is common on most turbo cars.
