Results 1 to 10 of 11
Thread: My home-made ram-air intake (work in progress)
    May 2013
    the Netherlands
    Thumbs up My home-made ram-air intake (work in progress)
    Hi all,
    I just wanted to share the process of the design and build of a ram-air intake for my twincharged Beetle 1.4TSI(118kw).
    I deciced to go for a software-development-like process:
    I started out with
    Step 1: Requirements.
    From important to less important:
    • Closed intake, connected to bumper
    • Isolated airbox to prevent air inside from heating up
    • Costs less than $100. Possibly even less
    • Try to make use of stuff already available in my garage.
    • Good looks
    Step 2a: Design ideas
    I was walking around with various ideas, since I've got some different filters here that I can use. Should I go for a big one (1, a big K&N filter), a small one with flow-enhancements(2, an Apexi filter...or 3, the same filter but with a tip a the front), or what? Some experts helped me out here, and I came to the conclusion to pick the bigger one.
    Step 2b: Functional design
    So I made a choice: go for the big one... but what would I need...? So I made this "sketch" in the most epic design tool ever given to man: MS Paint:
    What is what?
    Black: OEM setup, this will stay Original
    Green: Silicone coupler, from 3" diameter to stock factory diameter.
    Light grey: Aluminium elbow.
    Dark red: K&N Filter, 9.25" x 5.91" x 5.91", 3" diameter connector
    Purple: Inner part of the airbox, made from a protein cannister. It has a lid which can be opened/closed, which makes it easier to reach the filter in case I need to replace or clean it. The can is wrapped in heat-reflective alu-tape.
    Dark grey: aluminium outside of the airbox, made from a cylindrical shaped object. Between the two layers of the airbox, there's isolation foam.
    Blue: Silicone hose.
    Yellow: Hose-connector, mounted onto the lid of the plastic can.
    Red: Forge air-intake trumpet I still had lying around.
    Here's the Protein-can...first I was thinking about using the Siemens-Porsche Coffeecans in the back as airbox, so I can say: I've got Porsche parts in my Beetle
    Step 3: Measuring, technical design and prototyping
    Not much to say about this step... I did a lot of measuring inside the engine bay to see what would fit. Then I did a lot of test-fitting with various aluminium cans, including a Warsteiner beer can. In the mean time, I occupied the car with a temporary "hot air intake" setup, like this:
    In the end, the following turned out to be the best, using an aluminium trash can (the lid is not on yet, still have to drill a hole in it!). It's a perfect fit!
    Step 4: Implementation
    Now all I have to do, is drill a hole in the lid of the garbage can, attach it to the front, put all the parts together, and she's done! This will happen this weekend.
    Step 5: Testing
    not there yet!
    More to come!
    Jul 2009
    Geelong, Victoria
    love the ghetto approach! Will be interesting to see if there are genuine gains here, all the best
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    May 2013
    the Netherlands
    Thanks!
    I'm going to do a pre and post temperature log.
    Since this is pretty much the same setup as any commercially available solution, although it's not made of carbon fibre, there should be some gains and reduction in heatsoak.
    Jul 2013
    SA
    looks good!
    May 2013
    the Netherlands
    Quote Originally Posted by rshuwy View Post
    looks good!
    thanks guys
    It's done!
    My home-made ram-air intake (work in progress)-8q1b-jpg
    My home-made ram-air intake (work in progress)-pe9j-jpg
    And I added some additional isolation tape
    My home-made ram-air intake (work in progress)-oropc3h-jpg
    Jul 2013
    Caulfield, VIC
    Re: My home-made ram-air intake (work in progress)
    That's awesome. I want to do something similar but first I wanted to focus on the air ram for the stock pipe in my octy rs. It has a rectangular channel that splits up and down in to two, so rain goes down and air goes up. The problem is that the air goes straight through the rain hole, and has to bend upwards twice to make it through the intake rectangle.
    I want to keep the anti water efficiency while making it more of a RAM intake, and also increase the SIZE of the SCOOP at the front....
    I'm thinking some custom fibreglass in that area...
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
    May 2013
    the Netherlands
    Thank you
    The stock airbox has a water drain, maybe you can use it?
    Jul 2013
    Caulfield, VIC
    Quote Originally Posted by Chillout View Post
    Thank you
    Not sure which bit you mean. I want to make an air scoop covering a few inches down over the radiator, but it will pick up water. If there's a water run-off after that it will suck up engine air, unless I extend the run off pipe down to the ground? Hmmmmm
    My RS build thread
    Jul 2013
    Adelaide, Australia
    awesome job dude! probably works as good as any CAI
    Jul 2013
    Caulfield, VIC
    Hey mate, how did you sort out the maf tunnel, maf grid, and connection to the back part with the two metal clips? Can that part be bought or did you hack it out of the stock box?
    My RS build thread
