Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Thread: My home-made ram-air intake (work in progress)
    May 2013
    the Netherlands
    The 1.4TSI(118kw) doesn't have a MAF, so that's easy.
    The rest is just simple silicone hoses
    Quote Originally Posted by MountainBikeMike View Post
    Not sure which bit you mean. I want to make an air scoop covering a few inches down over the radiator, but it will pick up water. If there's a water run-off after that it will suck up engine air, unless I extend the run off pipe down to the ground? Hmmmmm
    On the bottom of the stock airbox, there's a drainage tube, which has a one-way valve and points down so it doesn't suck any water nor air.
